PARADOX
Founding Member
kep the firestation thing in the back of your mind, when traveling or whatever, most stations can either refill or will swap you out, keep in mind they will most likely have 'D' cylinders and can refill any cylinder as long as it has a standard regulator (big hole for 02 and 2 small holes for alignment pins) to the standard 2000 psi. if your going to be doing more long duration traveling, consider an inverter with the home 02 machine in the trunk, or "E" cylinders which will last a lot longer than the "d"'s. if he's on more than 3 lpm, you really want to think about the inverter setup
P
PS.... ok shoot me.. stealing the thread.. but.. Dad and Mom are settled. so I'm a bit better.
So what's going on in the world?
Wooo what a week. driving over 3500 miles. in 4 days. Tampa to Chicago, to NJ back to Tampa. For you Je'ssey boys.. Wow it got cold up there. I need a drink.
