Dave,
My setup is similar to Drew's, except I use a differnt pump, add a filter and remove the oil from a different place and inject it at a different place. I have a list of parts, with all the fittings and hoses and components and drilling the case, it gets real close to the $1k mark. I have not been able to test the setup on my own boat. This year I will and will have some data to share. At this point I do have a couple of drives out there with it installed. One customer told me he wasnt sure it was working. I told him to leave the pump off and see what happend to drive temps.. when they hit around 200* he turned on the pump and the temp dropped to 140* within a min. So it is a work in progress. Drew's system is comparable. I added a filter and when you cut it open, you can see just how much metal a Bravo produces, and all that is circulated thru the preloaded tapered bearing. The main difference is that I pull the oil from the lower and inject it into the upper pointing at the pinion gear. I perfer to do the modification to the case, which needs to be stripped down in order to do it. So I have not been offering a kit, due to the complexity of the case modifications. But if some one has no quams about taking a drill to a $1400 upper case, I could surely include some instructions..
Here is picture of my kit that I have put together. It is all top quality hoses and fittings. Outside is SS and inside is Aeroquip An hose and Fittings..
On another note, the top cap bolts shouldnt be backing out. Most of the time, the gear breaks and pushes them out. I use the XR top cap and a stud kit that I put together to help that LH drive out..
