P paston1 New member May 21, 2010 #1 Ok still have a lot to learn. On our SS7M with TRS and 502 Mag MPI what prop would you suggest?
htrdlncn New member May 22, 2010 #3 do you happen to know your x dimension or propshaft depth? helps a lot to close in on what prop would work well for you
P paston1 New member May 24, 2010 #4 Is there a formula for X dimesnsion? and how to figure prop shaft depth?
htrdlncn New member May 24, 2010 #5 measure the distance from the center of the boat bottom to the prop shaft centerline.
R rchevelle71 New member May 24, 2010 #6 Also going to need to know what prop your running now, and RPM. If youdont have that info, I would start somewhere around 24 for a 4 blade, 25 for a three blade with that motor/drive combo.
