The upper units on the TRS drive are very beefy with large gears. You can easily pull the top and back caps to check the gears for pitting and wear. If they look good and the fluid was clean I would concentrate on the lowers, because the lowers are the weak link with TRS.
Use the best lower housings you have, with the most/thickest material around the bullitt. Make sure the lower gears you use have no pitting(new would be best). All the bearings are available from local bearing distributors except for one vert shaft roller bearing(merc only). Shims are also available from merc. It helps to have a parts catalog in addition to the manual.
Two important things to know about with the TRS lower: 1) The lower verticle shaft roller bearings are preloaded with shims that are located in the upper housing, and setting that preload properly is critical to survival. 2) The right rotation drive puts the lower drive gear(prop shaft gear) on the back side of the pinion gear, making the rt drive the weaker of the two (since the gear is not supported as well, being in the thinner part of the bullitt). Hard shimming the right lower instead of using the crush ring helps eliminate bullitt flexing, adding to gear life. All the stock parts in a TRS are bigger in comparison to the same related parts in a Bravo, so in good condition with proper setup, they can handle 650/700hp in a twin engine application. With 600hp, I would expect the lower gears to last over 200hrs(400+ on the upper gears).
I ran TRS's with 550/600hp on a 311 Formula for over 500hrs(hard), and the only issues I had were wearing out the lower gears, and cracking a freshly rebuilt lower housing at the bearing carrier because the housing was thin(wore out) around the rear of the bullitt. A stock 1" TRS prop shaft is beefier then a 1" Bravo shaft(non XR), so prop shaft failure hopefully wont be an issue.
Good luck, LE
