rchevelle71
My suggestion would be to cut the vertical surfaces on the inside. I would try not to mess up the areas of the deck from the rail up including the top horizontal section. If you can make your joint/ blend repair in the inside vertical it can potentially be covered by an upholstered panel. It can then retain the original lines and profile as it does know.
Jim,
I am trying to picture this, but I still need to get the deck cap off at some point in the rear section, I dont believe I will be able to get the new transom boards in, in one piece, unless I get the top piece out of there? Also, remember these boats are very tight to work in, only 6'7" wide, I think I can do a more thorough job of getting the transom in correctly if I can access it from all sides. I agree covering it with upholstery would be an easier way out, and the cosmetics on the exterior may not be easy, but at least I can do the external cosmetic portion of it standing upright with beer in hand, not hanging upside down in the bilge trying to glass things together?
Rick
