From Bob Teague in an old Powerboat Magazine
TOE-IN OR OUT?
QUESTION: Can you explain the correct procedure for setting the drive alignment on a twin-engine boat? I would think that if they are not in correct alignment, you could be scrubbing speed.
On a car, there is a certain amount of toe-in, and when the car starts moving, that position will change. Is a boat the same? Does the procedure change with regard to the direction the props are turning?
ANSWER: Traditionally, the front suspension on an automobile is set up so the wheels have a slight amount of toe-in. Being that there is (probably more in the old days) a certain amount of slop or play in the suspension or steering components such as ball joints, drag links, bushings and so on, if the front wheels were not set slightly toed-in to keep a constant load in one direction, the result would be what is called a shimmy. A shimmy can lead to a violent shaking of the front wheels and the steering wheel.
The amount the drives should be toed-in or toed-out on a boat depends on a number of factors. The most common considerations are hull type, drive type, propeller shaft depth and propeller rotation.
Generally speaking, twin-engine V-bottom boats with the propellers spinning out are usually set up with the drives toed-in slightly. It is common to set the nose of the drives about 1/8-inch closer together than the aft end of the prop shafts. The theory is that water exiting from the back of the hull is being parted slightly by the keel, so setting the drives at a slightly toed-in angle would result in them running more aligned with the water flow. That is only a theory. What we do know is that certain boats handle better with varying degrees of drive toe-in or toe-out.
If the propeller shafts are high enough so the propellers are surfacing, the side load created by the propeller blades seeing cleaner water in the lower sweep of their rotation will tend to push the drive in one direction. Similar to an automobile suspension, there is a slight amount of play in the gimbal ring and transom assembly pins and attachments.
The side force created by a surfacing propeller will load the drive and transom assembly in the opposite direction of the propeller rotation. In other words, if the propeller is a right-hand rotation (clockwise from the rear), the result is that the force is the same as turning (or flexing) the drive to the right, and vice versa.
If your propellers are surfacing and turning out, the toe-in (nose cones closer together) will increase under load. And, if the propellers are rotating inward (port clockwise and starboard counter-clockwise), the force will tend to pull the prop shafts closer together resulting in toeing the drives outward. The deviation is related to the type and condition of the gimbals and transom assemblies, and how high the propeller shafts are when the boat is underway. The result of the movement under load should be considered when deciding what the ultimate setup is relative to drive toe-in or toe-out.
Catamaran hulls that are running a high X dimension with the drive placement very close to the tunnel present additional criteria to consider. If the drives are close enough to the tunnel wall so that the sweep of the propeller blade is seeing clean water exiting from inside the tunnel, there is a tendency to neutralize the affect on the propeller created by water exiting from the angle of the running surface of the sponson.
The bottom line is to get some advice from the manufacturer or someone who knows a lot about your particular type of boat and setup. Then start from a setting and make minor adjustments testing the boat each time to gauge the affect on the handling and efficiency.
Always measure the toe-in or toe-out with the drives trimmed to a neutral position and the steering straight. With an assistant, measure from the front of the center of the nose cones or bullets compared to the center of the aft end of the prop shafts. If you run the boat and discover that the toe-in measurement has changed by itself, the indication is that there is significant slop in your transom assemblies, tiebar or steering. A change in the measurement also could be because the transom assemblies themselves are moving on the boat’s transom and need to be re-torqued.
