Salt water Vs Fresh Water damage??
Salt water boats are more likeley to rot on the mechanical parts ( drives ,gimbals,engine and so on ) where fresh water boats more likeley rot on the wood and cores on the boat it self ( more expensive to fix) the reason of that is that fresh water carries more bacteria that eat the wood then salt water,,so on salt water boats it takes much longer for that to happen.
If u have a salt water boat that is cared for then the only thing u would need to check is the gimbals and intake,exhaust,maybe the heads if they are aluminum.
If its flushed reg.thenitshould not be a problem at all.
I would rather go with a in good shape salt water boat then fresh water.
I totally agree with you on the salt water and fresh water rot. I also believe that boats stored in unheated storage in cold climate areas will also have more problems with rot because of moisture freezing and expanding in transoms and stringers, this causes delamination of the plywood which allows the rot to spread even faster.Here again fresh water is worst because it freezes at 32 degrees were as salt water freezes at a lower temp.Look for Boats that have been in heated storage thier whole life. Heated storage boats typicaly will have less chance of moisture issues in the fuel system due to less condensation because of consistent temp.
Well I took the boat out mostly on the upper Chesapeake but now we have a place at the Jersey shore and now I'm not going to let the saltwater scare me.:cuss: I put my deposit down at a marina to rack store next year.:sifone:
Your wiring will turn to junk too in the fresh water. Your grounds will rust just as fast if not faster. Take care of your junk , fresh or salt and it won't be total junk. Don't take care of it and you'll be sittiing on the dock when I go by fresh or salt.
Copper and Aluminum do not rust. Copper tarnishes with fresh water but does not "RUST" ,Corrosion happens to aluminum in fresh water in the pressence of some form of acid, copper cleans in the present of acid i.e. Acid rain . Salt water corrodes both. Ask A Chemist.
Any form and shape of corrosion IS RUST !!!!!!!!!!!!!:seeya:
Funny how the salt water guys have twisted this thread into a well maintained salt water boat will be better than the fresh water boat.
Ive done my share of saltwater boating in the past, most of it involved the boat being pulled out of the water and flushed and washed at the end of each day with Salt Away. This year I took a freshly rigged Whaler and left it in the water for a month. I flushed and washed the boat inside and out after every day of use. After I brough the boat back north and started going through it I was finding corrosion everywhere. Brand new terminal strips, wire connections, and exposed metal parts underneath the console where badly corroded. The brand new aluminum jack plate was badly pitted, and any spot on the outboard that wasnt covered with rust or fogging oil was showing corrosion. This year I'm taking a few cans of fogging oil and grease with me.
Salt is without a doubt heavily taxing on a boat and its rigging, as long as you know what your doing and what to expect, the damaging effects can be kept minimal with the proper preventative maintenece and cleaning.
I think you're just reading it that way because you're from fresh water! ;)
My first post about this was how I've seen a good deal of unmaintained fresh-water boats and how since you "have" to take care of a salt water boat some may actually be in better shape. My view on this stems because some fesh water boaters tend to throw the baby out with the bath water when it comes to salt, like there's some kind of salt water monster. Seeing posts over the years like "I'm going to use my boat in salt water once, do you think it will ruin my engines?" I just laugh when I see that stuff.:lurk5:
I dont' think anyone is saying fresh is worse, there are just different things you need to look out for and neither are maintenance free. Sometimes I wish I was in fresh water so taking care of my boat would be that much easier. In fact the majority seem agree salt has much worse long-term effects than fresh, I don't think that's debatable...:seeya:
Freshwater or saltwater. Will it really matter 50 years from now? Use your boats and enjoy them. Life is too short.
