Propellers that gotta go!
Status
Not open for further replies.
Which ones do you still have?
By chance the H6-31P LH & RH ?
Darn it you were the first one I replied to... Don't see it now...ughhh!
I still have the H6 props and they are beautiful props.
Call me if your interested.
Julie
727-531-2255
Julie,
How much for the:
Mercury #6 BRAND NEW 5B 16.50 x 28P RH & LH labbed props!
Also, If I currently run 16.5 X 29 4 blade Mercs @ 5800...what rpm would I theoretically be able to turn the 28P 5 blades?
Craig
Julie,
How much for the:
Craig
Hey Old School,
Rule of thumb is of course to reduce one inch of pitch when adding a blade to maintain RPM. It usually holds true to within 100 ish RPM. So if the 29P
4B are running the appropriate RPM the the 28P 5B will run very close. But the additional blade will induce some lift. So this can also effect the RPM. This set of props has been tested only and the props were new from Mercury Racing, as I purchased them for this client. They have less than 2 hurs of run time on them....all witnessd by myself.
Thanks!
Julie
Hey Old School,
Thanks!
Julie
Julie
So...I should be able to turn the 28 five blades at the same rpm? Would it help in the slip department? How much $$$?
Craig:)
You guys crack me up! I received an updated price on the set of 28P 5B Mercury Surface Props, $6000.00 for the set. Test time only.
Julie
I have a 32 hustler whit 2 mercruiser diesels on xr drives 320hp@3800 rpm and thinking to see 72-75 mph and calculated to start with a pair of bravo 30 or 32 pitch .
do you have a idear or opinion that you think will work for me ?
the engines weight is almost the same as a BB so the balance and dry weight is about the same as a gasoline powered boat
thx ,
bor
I need to know the gear ratio, motor model and weight of the hull and year of the to get started.
Julie
So here is the deal....I want to move the rest of these props.
4B propellers = $225 each
5B propellers = $400 each
6B propellers = $600 each
Keep in mind most are labbed so its a lot of bang for the buck, with labbing worth $125.00 ish a blade.
Julie
727-531-2255
Status
