MILD THUNDER
Now, I have a handle on getting more money for this fix. would it be wiser for me to install a crossover kit and remove the circulating pump. remove the thermostat and purchace a thermostat controlled oil cooler? Also, talking to Eddie (who has been awesome help) i am going to install an oil tem gauge.
My only issue is I run the V-belt sytle system and 3 of the belts use the circulating pump. I am not in the market for a serpintine system. What do i do with the belts. Do i just go direct to the power steering and alternator with shorter belts?
And is buying a used crossover kosher or is there a good system out there? I do not need anything flashy. My engine is balck and blue and i do not care how it looks. it looks like a big bruise and i am ok with that. so is there any crossover kits that are painted instead of chrome?
I would keep the circulating pump and add a oil T-Stat and oil temp gauge.
