Use a good pump, perhaps even pay a marina to pump it out for you once. Then pull your drain plug, and install the Mercury Drain Tube kit appropriate for your motor/pan. The tube extends out of your bilge drain hole, and you drain out every last drop of used oil. Pumping leaves as much as 1 full quart in the bottom of the pan. I like changing 100% of my oil, not 90%.
