Moving parts off the shelf
1 Set of Comp Cams 1.7 take-off rockers.$150
Crane Gold 1.7 Almost new. 3 of them have slight damage from push rod, guide plate failed. $100
2 Blower Shop Inner cooler cores take-outs $300 each
2 sets valve covers, 2 piece 1 set missing lower plates $100
Bottom plates are chromed covers are powder-coated. Like new.
Like new helm unit -6 fittings, 75cc this was a take off it was replaced with a 160cc $110
JE Pistons 4.500 bore 1.395 compression height. These are take outs.
Need wrist pin bosses lightly honed from removing spiral locks. I believe I have 10-12 pistons
Used JE pistons inverted dome 4.500 bore 1.345 compression height. $300
do you know is tis would be to small a helm for a ITS transom assembly it is on a 20 cig with a blackhawk
It came off of a 33' Fountain with #4 speedmasters, twin Mayfair rams with 5/8 " shafts. We replaced them because; my customer had lost some of his movement in his right arm and we went to twin pumps and larger rams. It worked fine before we took it off.
