Mirage props solid hub / Rubber
kzcollectr
I have a set of 21p Mirages for my Formula but one had been replaced with a solid hub. Is there an issue running 1 rubber hub and 1 solid hub as long as they are matching RH/LH props ?
The operation won't matter. Some drives prefer the rubber hubs. Alphas must use rubber. Personally I suggest rubber hubs [non solid] on pleasure boats. The drives will appreciate it.
Oh, Welcome to the site
According to Merc the rubber hubs will only work for 450HP or less. I have run a solid hub for the last several years.
Welcome to the site. Just fyi, MarylandMark is SOS's resident expert about being an expert. :smash::cheers2: Just busting ya Mark :sifone:
Unless you are over 400hp go with the plastic inserts
The Alpha Drives will love it, so will the props if you have an impact
