lifter question
offshore24
Took a couple of hydraulic lifters apart to clean. Do they need to be filled with oil before assembly or will pre lubing the engine fill them?
drain the lifter...
get a spray bomb full size cap, fill it with light motor oil
assemble the lifter and submerge it in the cup
bubbles will appear for a few minutes
carefully take a #2 phillips screwdriver and pulse the lifter plunger several times to prime it, don't get it rock hard, just prime it
install and adjust to spec's, and pre-oil the engine
it'll be fine
