Hvac help??????????!!!!!!!!!!!!!!!
thanks guys. Letme check it out this morning.
The system is only 2 years old. The compressor fires up and seems to run fine but does "freeze up" and shut down after about 10 min. I'm guessing becuase the air handler isn't working properly.
You will not blow the Low Voltage fuse because of a freeze up. The only way to blow those fuses is because of a short in a 24v component or the wire it self. As far as the freezing up could be due to a low refrigerant issue. Check the caps on the condensor (OUTSIDE UNIT) the caps that are used on todays A/C's are junk and will allow refrigerant to leak out over the winter, change to the brass caps if you are in need of some I will ship you some @ no charge. Let me know. Remember kids when installing remove the cores before brazing and leaks will be prevented.:seeya:
