Top Banana
Icon/Founding Member
I was fortunate enough to secure a property in Fort Myers recently, so it is time to start looking for a proper boat to park in the back yard. My Envision is not quite right for this location. Criteria are ride quality, cockpit room and a full cabin. Something that will make for a pleasant run up or down the coast and maybe overnight onboard once in a while.
Based on my own research I think I'm looking for a 90's cig (cafe or gun) or formula (357/353 or 382). My wife would be leaning toward the formulas if the ride quality is there. I'm looking for real world advise on these boats based on my criteria. Questions I'm asking myself: is a top gun ride that much better than a cafe? A 353 will be relatively fast, but at what point does the water get big enough that we're getting beat up? Are there other models I should be considering?
Thoughts are appreciated!
Greg
Greg.....buying used is like buying used cars...always go for the latest and best you can afford. In this case that would mean a 2005 and up TS Top Gun...but that also means bigger power for the boat and the truck.
You didn't mention a budget, but think before you pull the trigger on a big used boat with big used engines....real world experience means big bills....and no warrantees.... to keep it running.
If you have a limited budget, work with a builder to build you a custom boat with new engines......things like the final finish to the cabin, can be done at a later date. This gets you out on the water now with a trouble free boat under you.
