S
SHARKEY-IMAGES
Guest
They are cutting it close to make it to the Miami Boat Show, but they will be there!
Other mods to the boat need to be done. Notching of a stringer to offset it so that the wider engine will fit. Means cutting out a cross bulkhead, adding another inch to the inside of the stringer then fiberglass back in the cross bulkhead. Fuel delivery lines also need to be redone with larger lines for proper fuel flow. Then lets not forget the sweet pearl paint work to finish off the engine compartment...:cheers2:
