Its going to sound great!!!!! Make sure you have plenty of clearance on the sides of the pipes on the hatch. The motor will rock some and you dont want any pressure on the bolts in your aluminum heads. Now fire it up!
As long as you are welding maybe it would be better to cut on the back side of the collector and weld the new 90 deg. there. It will be cleaner rigging the water dumps and less hose as well. Just a thought. :seeya:
MD
Have you guys tested yet,course how the boat is going to run at 5500 lbs legal weight now. Was reading the rule book and see that multiple step boat and drivers with no green cards have to be 5500 lbs.
