Davidmnc
Contributor
I have a 30amp (from source) to 50amp (to motorhome) adapter. It's about 18 inches long. We plan to cut off the 30amp plug and splice two 15amp "household" plugs into the adapter. Does your "RV Guru" think this is safe?
It would not make a difference. If the two 15 amp plugs are running off the same 15 amp circuit you still only have 15 amps. It's just split between two plugs. It's not the plug that is limiting you. It's what's feeding the plug. Just use a 30 to 15 adapter (http://www.go-rv.com/coast/do/catalog/page?index=A&pageNext=TRUE&dealerId=1746&pageNum=92), and plug it in the house hold plug. Then minimize your your power usage and you should be okay. There should be no need to cut any thing.
