2TR
Competitor
Why did you use heavy wood instead of lighter materials?
For the center counsel I wanted it strong, seeing as I have a arm rest / step going in that myself and Gary will be using every time we climb in or out of the boat.
Same for the foot rest and seat base. I have some foam core material that is a "little" lighter but I did not want to buy a sheet just to save 5-8lbs in this area, maybe I should have ??? I hate second guessing. :banghead: The Foam Core stuff I have will be getting used later in the project.
I did right down the weight of each part and it's not totally obscene, I think it's close to 30lbs added with what you see, but I'm going off memory so don't quote me. I think the Gaffrig Throttle/shifter system weights as much or more than what I installed.
