Bob Teague is CMI's biggest dealer, what the hell you think he is going to say!
As for 4-7 mph in a Baja with CMI's on a stock 496HO, NO WAY!
I've dynoed almost every header made on stock and our Raylar built 496's and I can tell you unequivocally that CMI Sport tubes make between 35-40HP more on a stock 496 than the stock Mercury 496 exhaust and the new CMI Sport tubes do about 20-25HP.
I know about that 50-60Hp dyno test originally done by CMI and I've never seen anybody in the industry re-create that result on a calibrated dyno, running the SAE standard with full accessories and water in the exhaust! You can confirm this with Bob at Full Throttle, he's also done a lot of header dyno testing and the results we have both seen in boats and on the dyno are about the same and pretty consistant. Bob, will also confirm with his propshaft dyno that water in the headers takes away about 15-20HP all by itself as we have seen in wet tests.
As Mild thunder has said if we were comparing Merc's older MPI and log manifolds the increase would be larger and when you go up to 500HP plus on the 496's you also se a slightly bigger increase in power, about 10-15HP more due to the better breathing required. Lets face it there are no realy cheap 40-100HP increase upgrades for any bbc engine especially the 496 family. We oughta know, we've only done hundreds of them!
Best Regards,
Ray @ Raylar
