Its the #3 assembly. The ball should not be loose.[/QUO
Roger, but I was speaking in ref. to the detent assy. kit does it include the ball. Illustration does not show a ball and I did not get one with the parts. but they were loose from the shop. Just curious if the ball was included. Also does the taper go into the housing or does the ball set into the taper?
Thank you all for the help
Your confusing me. The ball is part of the tube thingy that is called a detent assembly. It is installed as positioned in the picture #3. If the ball comes out it is worn out.
Understood, mine is in need of replacement, worn out.
The exploded view is of the spring/tube assembly~does the S.S. Ball come with the kit?
When installing the New Tube/Assembly>the tube has a tapered end, does that go toward the ball to secure it, or toward the housing and then press in the ball?
How do you press in the ball with the new assembly?
cables awesome, all set. If anyone needs some I can get them direct for around $73 for an Entire kit, o rings, bellows, etc.
So, what is the deal with the Drive shift ball?
Here are pics, I can not get the cover back on is the ball supposed to be inserted into the cover? Or is it Free floating?
Stbd side is in the cover, port is out and Not cooperative
Pics
