Can I have my lab finished Bravo I 32P "blade rake" changed to lift the bow of the boat? Anyone know if this is possible, and if it will change the slip ratio of the prop? Change of boat speed?
I would thing it would be easier to cut the difusser off to eliminate transome lift. Check with one of the propeller gurus like bblades or throttle up, they would know exactly what to do.
Combinations of rake changes including cup height changes, tip bends and diffuser removals will aid in bow lift and decrease slip numbers.
Rpm can rise or fall depending on current numbers and boat type. It would be best to call and discuss this.
