Hi, Just got a problem I am having I got a 502mpi built to a 540 when I am idling my water temp gauge is showing 135* when i plane out and start running the temp starts to climb to 175*/180*. It has a 140* t-stat in it. I have had the sender checked along with the gauge both are fine. I have checked all hoses and coolers for blockage nothing found. Its got me stumped.. Also the port riser runs cooler that the starboard side? Also I have put a new raw water impeller in it. If anyone has ideas let me know. thanks everyone
Thread: Water Temp Issues?
Results 1 to 8 of 8
- McHenry Illinois
- 10
08-29-2009 08:50 AM
- May 2009
- 43
08-29-2009 09:06 AMI have your same boat. My does the same thing. My one riser is much hotter than the other. I have also removed all my hoses ,flushed everything, checked for blockages,replaced thermostat and rebuilt my raw water pump. My boat gets as hot as 180 on the gauge when really running it hard. I have talked to many people and we all seem to have the same problem. My guess...That is just how it is.... The engine oil cooler catches any debris that may have been a blockage.. Jeff Wurl
- 37,507
08-29-2009 09:46 AM180 wouldn't bother me in the slightest. What is your oil temp running at?
08-29-2009 05:28 PM
like rat said..
08-29-2009 06:47 PM
A 502mpi should have a 160* Tstat in it anyway. You could be sucking a little air mixed in with the water at speed. My stock 502mpi runs about 170* on the guage most of the time.
- 37,507
08-29-2009 06:54 PMThinking about this. Would it need bigger injectors for the larger cubes/more horsepower? Running slightly lean?
- Jan 2009
- 207
08-29-2009 07:20 PMhttp://www.seriousoffshore.com/forum...ead.php?t=8435
Start looking at this thread, 180 isn't going to be normal with a140 degree stat.www.merperformancemarine.com
843-399-8785
09-02-2009 07:03 PM
i would pull some plugs and take a look at them ??? to lean the temp will go up and to much timing ..
