Results 1 to 20 of 37
    My weekend's " Holy **** " moment!!
    Seaford, VA
    I have heard of people saying it happened, but never in my life figured it would be me....
    Had a parking brake cable snap this weekend at the ramp - luckily I wasn't quite out of the truck yet and was able to slam the brakes on!!!
    I am buying wheel chocks this week and am going to use them religiously!!!
    Founding Member Tony's Avatar
    Ohio
    DAMN! Glad to hear nothing bad happened.
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    Mine broke the other day too. Luckily the parking pin held it.
    That's not a good feeling! Manual or Automatic?
    Seaford, VA
    Mines a manual - and for a brief moment I really had wished it was an Automatic!
    wow! Glad everything was ok!
    In Fond Remembrance. StraightJacket's Avatar
    In the Ghetto ,Far South Side Chi town
    Quote Originally Posted by Seafordguy View Post
    Line lock , like we use on the drag cars works as a good safety 2. Just install it on the line feeding the rear brakes. Toggle switch on the dash and your in businesss
    Seaford, VA
    Quote Originally Posted by StraightJacket View Post
    Interesting....
    Never would have thought of that...
    Serious is the BOMB!
    My sister was at the atm machine last week, she is short, stood on break peddle to reach the machine... blew a brake line, pedal goes to the floor.... has she been driving... OUCH!
    Contributor
    Somewhere between Lost and Found
    That happened to me while I was sitting at a traffic light a couple of years ago, and no, I wasn't standing on the pedal.
    Registered insanity's Avatar
    Perrysburg, OH
    Did this on my old truck that I converted from drums to discs on the rear axle, specifically for using it as a parking break at the boat ramp. The disc calipers with the parking brake lever were outrageously expensive, the line lock was the easy fix
    Perrysburg, OH
    Quote Originally Posted by RichL View Post
    Happened to me a couple months ago too, slammed on the brakes for a quick red light and blew out the rusted out line going to the rears. Managed to make it to the gas station, fill up with brake fluid, stop and check it again halfway to work, and finally made it to the shop to have them fix it (400 miles away from home in February, had to pay somebody else that time).
    Registered Scarab KV's Avatar
    Good idea. I knew there was a reason I never threw it away
    Seaford, VA
    Jesus - the dealership called and wants 675 dollars to fix it. What a bunch of crooks. Then to "earn my business" they offered to screw me less by knocking their labor rate charge down to get the total to 600.
    Told them to give me the parts and I'd do it myself, despite the fact they are going to charge me $99.00 for a diagnosis fee. I knew there was a reason I had never taken a car in for anything.....
    So, do you mash the brakes, then hit the switch?
    ________
    Mine's an automatic thankfully. I have an old linelock laying the garage. I think I might just put it on.
    I had the "exact" same thing happen to me last year right down to the ATM machine. I guess brake line was a little worn already and the extra pressure I put on it was all it took. Kinda freaked me out.
    Turned out to be an easy fix. It was a rear line that went across my back axle. $70 and about 15 minutes of work. All was good.
    Buck
    A thong is like a barbed wire fence, it protects the property but doesn't ruin the scenery.
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    That happened to me in my last truck.
    I was just leaving work, still in the parking space and stood on the brake pedal while I was trying to get my smokes out of my front pocket. Pedal went to florr and wouldn't pump back up. I was spraying brake fluid out the rear left wheel well.
    Dealership????
    I took my truck to a local shop and including the tow it was under $200. And ready later the same day.
    I had an old toyota pickup that I had a brake line rust through and bust. I was coming to a stop at a light. the pedal went to the floor but it still stopped because of the seperate circuit for the front wheels. Scared the chit out of me though. It cost me about 6 bucks to fix and an hour maybe.
    Yes , the same way you would when on the line at the track only a toggle switch not a momentary switch. Just apply the brakes, flip the switch and your all good . Make sure they switch is wired to a constant positive lead other wise if you shut off the key it will de-energize and release the brakes.
