Results 1 to 20 of 28
    who sells heat shrink tubing?
    Lake Nasty
    Need some for new battery cable system. I have some smaller diameter, but need larger.
    Toronto
    I always got it at home depot, but they probably do not have anything large enough to battery cable
    Lake Nasty
    I am thinking 1 inch. Maybe 3/4.
    Lake Nasty
    You would think that the guys who sell bulk battery cable, and ends might have it. But no.
    I know the alternator/starter/battery shop here in Zeeland has it. Call around to yours.
    From the NAPA website
    Attributes:
    Type:Heavy Wall Polyolefin
    Adhesive Lined - 3 To 1 Shrink Ratio
    Features & Benefits:Certified For Direct Burial Applications
    Adhesive Layer Provides Water Tight Seal & Protects From Oxidation & Corrosion Yet Remains Flexible For Life
    Product Features:Heavy Duty Thick Wall Tubing Offers The Greatest Abrasion & Corrosion Resistance & Highest Strain Relief For Maximum Protection In Harshest Environments
    Meets Mil Spec 23053/15 Rigid Requirements For
    Gauge:2 - 4/0 Gauge
    Color:Red
    Length:9.5"
    Additional Contents (2) Heat Shrink Tubes
    on the moon . . .
    Del City wire has some nice stuff
    http://www.delcity.net/
    www.mcmaster.com for all your shopping needs
    Registered insanity's Avatar
    Perrysburg, OH
    How much do you need and what size cable? I collect it from work and have quite a bit, black and clear. Some of it even has a heat activated adhesive inside, works great for keeping the sheath from pulling back from the terminal.
    Lake Nasty
    I did, but no. The NAPA store may work.
    Lake Nasty
    I was hoping for red, probably about number 2.
    Thanks though.
    Lake Nasty
    Thanks for the online ideas Dave and Sean.
    Thanks for the input everybody.
    I am going to try the local NAPA store after work and see what they have.
    I figure I need a couple of feet of it.
    Charter Member ROGUE's Avatar
    Ohio
    I have quite a bit too, red or black, adhesive lined, all the way up to 2" dia unshrunk. Make sure you get the adhesive lined stuff as it keeps the moisture out of the bare wires.
    Lake Nasty
    Quote Originally Posted by ROGUE View Post
    That would ship cheap.
    Wanna sell a little?
    mrfixxall
    Fry electronics has a chit load of it,red,black, yellow 3/16 to 1+''
    Ohio
    I sent you a PM with my number. I can send you what you need as soon as you call. NC except for the shipping.
    Typical expanded vinyl heat shrink isn't likely to do the job well. The local place that makes up cabling for me uses a bonding rubber. It's fairly thick and chemical resistant. And it has the adhesive liner that bonds it. And from the looks of it, it shrinks more than the vinyl's 2:1.
    Lake Nasty
    Got it. Thanks.
    There is some three to one stuff that I saw out there.
    Got it. Thanks.
    Did NAPA have the 3 to 1 with adhesive as their website said?
    Lake Nasty
    They have it. Heavy walled with mastik. The real deal for batteries not electronics. The size for number 2 battery cables was like 2 inches in diameter and pretty dam thick.
