Hey Dave, I need some advice on repairing some paint damage. The side of my boat was keyed while at the dock last year and left about 50 1/4 inch round "scratches" in about a 3 foot long by 10" wide band. For background info, my boat was Imroned white several years ago and the paint is in fair to good condition. I've filled in each "divit" with 3 successive layers of paint; below each hole is a drop where the paint ran that is about 1/16 inch thick. What do I do now? I've got some 320 and 600 wet/dry sheets, a 10" sanding block and some 3M marine rubbing compound. Help. - Jeff
Thread: Vandalism damage
Results 1 to 20 of 23
04-18-2009 02:28 PMPeople we meet in life are either a Blessing or a Lesson
- 37,495
04-18-2009 02:58 PM
live and learn
04-18-2009 04:49 PM
That sucks!!!!!! Sounds like a good time to have 10" wide graphic stripe added.
04-19-2009 01:13 AM
I'm having some trouble understanding what has been done so far. You filled each little scratch with paint and it ran? Did you spray the sides or were yoy trying to fill each chip individually?
- 1,125
04-19-2009 04:11 PMFlat razor blade and scrape the run down, then wet sand and buff. hold the razor blade straight vertically and it will knock it down like this... |
04-19-2009 04:39 PM
thanks rob, i'll give it a try - jeff
04-19-2009 11:00 PM
yep. be careful though with the blade. Best thing to do is take a piece of a wood paint stick and wrap a piece of sandpsaper around it and block it down with that. you actually have to use a fairly course grit (by color sanding standards) and slowley knock the high spots down to a point where you can use a finer grit. I would probably glide 600 over it to get started and ass the level starts to approach the surface start to step up the grits. If you start with finer stuff like 1000 you will never be able to level it. at any rate the repairs will still be visible but I'm sure an improvment.
04-20-2009 11:00 AM
thanks Dave, I appreciate the advice- Jeff
04-20-2009 11:41 AMYou can buy a run shaver at an autobody supply store. it's like a miniature block plane that uses a single-edge razor blade.
Imron is way tougher than regular paints. I don't know what kind of success you're going to have. You'll get best results a couple days after painting. After a week, it's much harder. If you do any sanding on it, use the absolute finest paper you can and take your time.
FWIW, Magnum paints every one of their hulls with Imron. Even those monster 80 footers. The spray it right in the shop- no booth. Then they wet sand the entire hull by hand.
04-20-2009 11:48 AM
you will never level the surface using the finest paper, you really need to knock the tops down first than step up to the finer stuff. Thats why its important to glide the courser paper over just the tops. Its not easy but the only way to do it.
yikes . . . wet sanding an 80 by hand . . . they do look good though.Throttles- Cleveland Construction/Traffic Light Racing 377 Talon cat
04-20-2009 01:23 PM
Thanks again guys. If it turns out ok, I'll post a photo, if not, well.............
- Jan 2009
- 59
04-22-2009 10:04 AMDuPont has issued a response about 30 years ago to buffing, don't buff Imron it will scar the paint it will lose it's sheen. Paint a stripe. Two part polyurethanes are really rubber. Let activated Imron cure in a bowl= rubber.
04-22-2009 11:28 AM
yikes; thanks excalibur, i haven't done anything yet - i'm gonna proceed very carefully - jeff
