What are you running?
Results 1 to 20 of 65
- Frankenmuth MI
- 109
10-27-2008 01:26 AMI found that the amsoil synthetic combined with cryo treating/proper gear surface prep seems to give the best life of the gears under extreme hp situations. I tested alot of gears with royal purple and after switching to amsoil have realized it works better. Merc hp is fine for stock boats but I had no luck with gears using it,Smitty
272 Baja
1115 hp
ANY QUESTIONS???
"Here's to swimmin with bow legged women"
- 3,107
10-27-2008 11:16 AMSmitty,
Who does the treatments in our area (NJ)? I have one of my lowers apart with about 20 hours on new gears so I figure it would be a great time to get the treatment done since the gears have taken a "set".
I also use the Amsoil gear lube. Are you using the marine lube or the severe gear?
10-27-2008 07:16 PM
Ditto Amsoil gear lube on the wett sumps
- Frankenmuth MI
- 109
10-28-2008 01:47 AM[QUOTE=Chris;8276]Are you using isotropic micropolishing on the gear sets? If so, have you tried the REM process?
Among other things,the gear treatment field is constantly evolving,Smitty272 Baja
1115 hp
ANY QUESTIONS???
- Frankenmuth MI
- 109
10-28-2008 01:56 AMI don't know who does the gears in the Jersey area but there are many places thru-out USA.I have a shop that I work exclusively with that does my gear treatments,it's a multi step process,we have experimented with different treatments and processes to try to find the most durability. I'm using the severe gear Amsoil,I'm very happy with it. You can pm me if interested in getting gears done,Smitty
272 Baja
1115 hp
ANY QUESTIONS???
- Stockholm, Sweden
- 193
10-28-2008 08:19 AMI'm using cryo'ed gears and Royal Purple 75W90 and oil cooler, filter and circulation pump (From Mr Gadgets/Dick)). Still during break in with 6.5 hours.
Replaced the filter after 4.5 hours and there was pretty much debris in it and that was from 0-4000rpm with no boost. I will change the filter after another 1-2 hours since I'm putting on some boost now.
The cooler and filter seems to works very good!
- 3,107
11-04-2008 02:01 PM
Amsoil AGM - Marine Gear Lube
11-04-2008 11:42 PM
Torco Synthetic RTF
Tom
11-05-2008 04:04 AM
Synthetics = twice the cost, half as good.
We went out and made some of our own. My brother did the logo, look for the W. It is a mineral base with one additive.
If you are running a wet-sump... High temp type oil (green or yellow).
If you are running a merc dry-sump (ie fake drysump).... see above.
If you are running a weismann dry-sump...... mineral base 30 wt gl5/gl6
pick your poison.
11-05-2008 02:39 PM
Nice Fangs, Pat....
Tom
- Edgerock, MD
- 1,947
11-05-2008 02:54 PMI run the HP Merc stuff in my wet sump 6's.
- 3
- I live in Holland, Mi. Along the Lake Michigan shore.
- 36
11-10-2008 02:53 PMI have been running Royal Purple with Prolong engine treatment added for 12yrs or so..
11-10-2008 02:59 PM
I run the HP Merc stuff in my Imco. No problems yet.
I would have thought more guys would be using Merc stuff.
