Results 1 to 10 of 10
    557 HP outboard in the works.
    I am a little skeptical but why not?
    http://www.autoblog.com/2011/03/12/v...-in/#continued
    Registered htrdlncn's Avatar
    Jan 2010
    Lake Travis
    They had them at the Miami boat show.
    Awesome units for sure.
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    That's quite an endeavour.
    But how does it SOUND??
    Jan 2010
    Lake Travis
    has dual 3.5" exhaust, should sound pretty damng good..
    http://www.seven-marine.com/motors/f...-and-benefits/
    I kinda daydreamed through the video.....did they mention a weight?
    weight
    Sponsor / Charter Member
    1,000 pounds
    Lake Oswego OR
    If you're gonna go the 4 cycle route, you may as well take it to the limit - what a BEAST!
    Registered BDARCHER's Avatar
    Dec 2009
    Millington Tn.
    With a couple of those on back. Black Thunder could build a 46 ft CC fishing boat. Now that would be a big, wide, nice riding, fast overnight fishing boat. That seems the way things are going.
    Founding Member Tony's Avatar
    Ohio
    I cant belive there is no actuall footage of one running yet. Also, whats 2 to 3k lbs of dead weight clipped directly to the transom going to do to the boat over a period of time?
    As much as I hate to be a buzzkiller, I kind of think that the project is stillborn. The first time I saw it I wondered how they got the 557 hp rating after sending the power through several 90 degree turns before it gets to prop. To me, it looks like they put together some components that resembles a drive package with a high center of gravity put a shroud around it and an outboard bracket in front of it. I still think that it's kind of cool, but then again, I also think that the a snowblower with a big block chevy and zoomie headers is cool too.
    I think that sombody should have done an "intervention" before it got this far.
    I hope that I'm wrong and that it works out well for them. I certainly don't get any enjoyment from seeing someones hard work and effort not turn out well.
