BT guys in need some help, my toilet will not flush when I press the button. I have ran head lube in it, holding tank is empty, not sure why it is acting up.
This all started after 4th of July, when I discovered a tampon stuck in the Toilet (damn women). It will work from time to time, but it will pop the breaker on the wall next to the flush button, after resetting it then I try it again. Most of the time its to no avail. It does not seem to matter if its hooked to shore power or not.
please help,
thank you
Eric.
Thread: Help... Bathroom
Results 1 to 14 of 14
09-07-2010 08:15 PM
09-07-2010 11:41 PM
Sounds like a chitty dilema.... Sorry I'm not much help!
09-08-2010 08:21 AM
Mine did the same thing it took a new grinder at the base of the toilet.
Not to bad to change!
- Jan 2010
- 41
09-08-2010 10:11 AMI had my old one all apart too. It all comes apart below the toilet bowl. Remove the plastic cover around the toilet base and you'll see the bolts and such. Not to difficult to take apart. May just be debris in there that needs to be removed. I found seals, motor, and anything you might need at West Marine. Might want to put a sign on there though that states toilet paper and human waste only.
09-08-2010 02:32 PM
Both of mine did that. Just replce the motor and grinder set up. Its a Chitty job.....
09-08-2010 05:22 PM
Someone on SOS had a sign in their marine head that said something like " If you didn't eat it or drink it first, don't put it in here"
And for you Black Thunder guys this thread is showing amazing restraint!Parabellum FJ²B
09-08-2010 09:47 PM
Thanks for all the imput, I guess I will tear it apart. Yes Saxman and Endeavor, its gonna be a Chitty job, lol.
09-09-2010 09:00 AM
My BT had a very small wire like speaker wire from switch to chitter. It ran slow and didnt flush very good. I changed the pump and motor it didnt help. Then I increased wire size. Now it sounds like a blender on high. I had some chickeys flush pads in the both toilets in my Bluewater. I have DO NOT FLUSH ANY THING THAT DIDNT COME OUT OF YOUR ASS on the wall. It doesnt matter.
09-09-2010 10:00 AM
Feminine products should not be allowed on any boats!!!!
- 37,466
04-10-2013 11:02 PM
Since spring is around the corner - may be a good read for some
