What distributor/ coil are you guys running? Got a 540 N/A.
Thread: Distributor / coil?
Results 1 to 11 of 11
09-07-2010 09:17 AM
09-07-2010 09:19 PM
http://www.jegs.com/i/MSD-Ignition/121/85551K/10002/-1
I can get this setup for under 400.00
09-08-2010 08:39 AM
msd also. tried hard to run the stock but it didnt happen. just get the msd and be done.
09-09-2010 08:25 AM
timing would stary to retard @ about 5000 rpm then hit rev limiter at 5200. set timing at 32 deg @ 3000 that put base timing at 8 deg. black soot on transome and loaded plugs . now better timing curves,base time about 18. better idle and cleaner running motors.ps i also tried to keep the mec fuel pumps , didnt work just get the electrics and be done. good luck. brian
09-09-2010 08:29 AM
hmm... I still have thunderbolt IV. I have a 22' advance, but it only advances 18' at 3000 rpm. Ive got black soot on transom bad. Ill be gettin an MSD today. I just put on a mech 110 gph holley. I guess i should go ahead and swap to electric as well. Thanks for the heads up man. Ian
09-09-2010 02:38 PM
any time. put a fuel psi gauge on and you might be able to keep the mec pump. i held 6 lbs till the 2ndaires pulled open then psi went to 3 lbs. you want a min of 5 max at 8. good luck . ps i used the lightest springs and the largest bushing on my msd.
09-13-2010 12:27 PM
Dont waste your money on msd.... if you do buy msd buy a spare module you will need it!
Here is a better system and won't leave you hang in..
http://www.performancedistributors.com/marinedui.htm
