I just got a set of Powerflow exhausts and the pressure/return line fittings on the back of the power steering pump will not clear. I went to the Imco site and did not see a solution.
What do I need to do to make it work? Is there another power steering bracket that I need to get? Engine is a 1987 420 Mercruiser, all original power steering/alternator brackets.
Results 1 to 16 of 16
09-05-2010 08:13 AM
09-05-2010 08:54 AM
If you move the PS pump to the fully adjusted side will everything clear?
The pump will move over a couple inches when you go to put the belt on.
May have to get a shorter belt if yours is streached, or the wrong belt now.
I remember on my last bolt my GILS pretty much touched my PS pump as well when I installed them
09-05-2010 09:13 AM
It will not adjust at all. It just barely had clearance enough for me to stick it on fo the picture. In the second picture the return line tube is hitting the water inlet on front of the manifold. The pressure line is almost directly in front of the water inlet. If the inlet on the manifold was removed it would have clearance for the return line but the pressure line will most likely still hit. I kinda hate to band saw off the front water inlet and weld it shut, but that would give some clearance.
09-05-2010 09:36 AM
Yeah,,,, looking at the pictures I see what your talking about
That bung is messing you up,,,,, hopefully someone with powerflows will chime in,,,,, you cant be the first !!!
09-05-2010 10:03 AM
If the bung was band sawed off and welded closed, and I made a 1/4 inch spacer to go behind every bracket bolt and made a 1/4 inch spacer for the water pump and drive pulleys, that would move everything out 1/4 inch and I think that would be enough.
Surely there is a better way than all of that. Anyone?
09-05-2010 10:15 AM
I bet someone makes a relocation bracket. If not how about a tankless steering pump,with a remote oil tank,something like the merc 496
- 37,509
09-05-2010 10:21 AMI'd check the offset of the power steering pulley and have a custom billet one modified if nothing else works and just space the pump out 1/2 inch or so.
Some of the later pulleys must have different offsets that may work? Anyone????Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,509
09-05-2010 10:25 AMAnother option is an aftermarket bracket as said. You could have it cut and rewelded for any location you wanted because billet welds well. The stock cast one I'm not so sure I'd cut and weld it to move the pump a little higher.
09-05-2010 10:51 AM
The offset power steering pully is a great idea. Unfortunately there is only 1/4 inch between the existing pully and the closest point on the pump. Diameter would have to change a lot to clear it. Then it would change the speed of the pump.
- 37,509
09-05-2010 11:02 AMWonder about a relocation? Or aftermarket pump?
http://www.cpperformance.com/p-13714...embly-bbc.aspx
Upper Starboard Side Power Steering Mounting Bracket Assembly - BBC
620-910080
Upper Starboard Side Power Steering Mounting Bracket Assembly - Fits B/B Chevrolet
This power steering mounting bracket is designed for a upper starboard side mount on big block Chevrolet engines. This heavy duty steel bracket is powder coated black for corrosion protection. This bracket accepts most popular GM power steering pumps and is supplied with the necessary mounting hardware.
MSRP: $195.00
Your Price: $179.99
Quantity:Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
09-05-2010 11:35 AM
Looks like you have room to shift the pump up and outboard a little, how about taking a metal plate and step off the origional bracket then use spacers made from the same plate to bring the pulley allignment back in place
09-05-2010 11:35 AM
of course you would need a new belt
09-05-2010 01:42 PM
Any one else work through this same problem?
10-11-2010 08:45 PM
I am running the same powerflow set up on my 468. Here are some pictures. Mine clears by a lot. Looks like we have different brakets.?
10-12-2010 12:03 PM
You have one of those motors that just doesn't line up, Merc has a few of them. Either give us or IMCO a call and you will need a (IMCO 04-9355). This bracket will kick the P/S pump and alternator off to the side so you can clear your Exhaust system and not hit the P/S return fitting.
Here is a link to IMCO's website w/ the part!
http://www.imcomarine.com/ca_store/i...roducts_id=656
Give either us or them a call and we will get you all hooked up! -Eric
"We Have Everything But The Water!"
