where do I lift?
old377guy
Hey guys,
I borrowed 4 Yardarms for lifting my 38' Scarab off the trailer - I'm going to do a bit of maintenance on the trailer over the winter. I've placed two of the units at the rear and the front two 12 1/2 feet from the bow. Any thoughts or experience with correct placement? Thanks in advance. Jeff
might not lift with that set up. Might want to use a small fork truck with extended forks and boat jack stands. Good looking boat and shop! good luck
Thanks Toasty. A friend used this setup to lift his 42 OL off this trailer but I'm mostly concerned with balance and jack placement. - Jeff
please be sure to "tie" the yard arms together at the tops, so thay don,t get bumped or try to pop out,, ",tie accross from each other" good lu ck
block the keel once off trailer. just like a marina during winter storage..dont trust yardarm even with lock pins..support bottom outboard as well for balance..
Hey guys,
The way u got it ,,is perfect, ( i would put the front ones more back, like where the steering bulkhead is ).......as soon as u get the trailer out , make sure to put some wood in the center of the V and u be fine .
The way yardarms are build,,they can not move once the weight is on them !!!!
Place one at each corner square with the transom first. Then I would move the 2 others further aft. Right where the cabin bulkhead is (normally right at the base of the winshield. As someone said, cross tie them with sufficient lines 4 ways. as soon as the trailer is free place one set of blocks directly under the engines. Then run a set up to curve of the bow about every 4-6 feet. Just take your time.
Thanks Mark, Daredevil, Racedad and Bill;I really appreciate the input. I was planning to let the boat down onto appropriate keel and strake support areas. You just can't beat this forum. - Jeff
Hey Old377guy ,just like Dollabill said take your time and you really want to keep everything pretty much on a straight surface ( chime ) when lifting the boat a little curve is allright but not to much .
Always place your yardarms at bulkheads. Never put them between bulkheads or else you run the risk of permanent warpage.
Those yard arms are bad as$. I wish I had a set. Each jack is rated at 10,000 lbs or more. They will not move on level ground. No need to tie them together. Are the engines still in the boat? If not your placement is good. If so like others have said I too think the forward set should be moved back to the bulkhead at the base of the windshield. Use them to remove from trailer. Set the boat on conventional jack stands or blocks for the duration. Don't leave it on the jacks.
I don't think the wood on the pads is a good idea.
I agree the wood on the jacks scares me. Frankly, the jacks scare me. Never liked using them. But you gota do what you gota do....
And yes they will and do pop-out. I've seen the results. Not pretty. On a typical hull like ours, with sufficient deadrise, there's more force outwards than down in certain situations. Don't take chances. Chain them together.
I suppose anything is possible if not used properly. I have not seen it happen. I have used them on countless boats. Always with 2 people. Always jacked them up and down evenly. Always used the pads never wood. Always positioned them on a flat surfaces. Never used them while working on the boat only to remove and return to trailer.
They are not work stands. The boat should never sit on them long enough to chain them together. As soon as the trailer is clear the boat should be set on blocks and/or stands. Nobody should ever get in the boat while it is on the jacks.
