Debating this on another forum. I am installing full Zeiger dual ram hydraulic steering on my Donzi 22 Classic with HP525 EFI. What should I use to attach the ram plates to the transom?
I got your nuts hangin' hehe. Yes there will be nuts and bolts and SS inserts to limit compression of the transom. I'm getting mixed recommendations on the adhesive/sealant though. I will use what this poll ends up indicating.
5200, you only have to use enough to seal around bolts, not neccesarily enough to bond the ram to the boat. if you use 5200 you Never have to worry, it won't budge unless you want it too..
The 4200 and 5200 have the same sealing properties. The 5200 just has twice the adhesive strength. The bolts are going to be what holding it on, so I would go 4200.
Wow, it's dead even! All boat hardware is held on with fasteners in addition to the sealer/adhesive. If the 4200 is just as good then why do they even make 5200.
Because it makes 3m money! The poll shows it is an even split so people are buying it. I used to use 5200 on everything because I read about it on on of these forums years ago, then I tried to remove a swim platform we used it on. It took off gel and a couple layers of glass in places! 4200 will work just fine for your application, but 5200 is twice as strong.
You just have to decide if you want to be able to remove the bolts from your rams and still run the boat.
