website building
phragle
Does anyone have experience?? there are a ton of programs out there, looking for pointers on finding which on is simple to use, intuitive yet allows cut and paste scripts etc, any suggestions?? I was looking at the coffecup html editor as it can swithch between wysiwyg and html. I am not fluent with html, but I can somewhat reverse engineer scripts to make some changes etc. Thanks
I used http://www.1and1.com I found it pretty easy.. It took a while to pick the template I wanted. The more you use it the easier it gets. It is easy to make changes too. I got three domain names for 10 bucks a month. Just the basic package. My sites are listed below if you would like to look to see what I did. I knew nothing when I started a year ago.
I might get some credit if you use me as a referral.:)
Phragle I would be glad to copy a program i have and send it to you. It's one of the easiest programs I have came across for building sites....This has templates to use or you can start from scratch and build it all original.. I'm not real versed with html code and all that..the program does everything for you except lay it out..although you will have to find a place to host it, but that's cheap and easy.
