Water Separator/Fuel Filter
Dan The Man
I,m looking for a cross reference # to this discontinued Fram Filter #PCS5062M. This filter is 6" long. I've already checked w/ Teague, Eddie Marine @ NAPA and they have all crossed the # to filters that are anywhere from 7.25" to 8" long. As you can see, any longer than 6" and it's hitting the stringer. I really don't want to have to relocate the assemblies. Any suggestions are appreciated.
Thanks everyone. Problem solved. (I think, as long as they show up at my door.) ordered the exact Fram model from boatfix.com.
Are those Teague mounts? I the Teague mounts and have Napa filters on mine and I think they're no longer than 6 inches with a petcock on the bottom. Can't rememeber the number right now but I can find out if need be....
If you get a chance please let me know the part #. I ordered from boatfix.com only to find out they too are out of stock with no replacement available. It seems like someone would have the 6" version. Who knows? Thanks
No problem, I'll look it up when I get home... I have the numbers written on the wall in my garage next to the work bench... ;)
That's what used to be on my boat and I have the KE unit. I've been using the Wix replacement that has the drains on the bottom. If you need the number, I'll look at the spare pair when I get home.
Craig
I can't believe I cannot find the damn thing anywhere. G36 The NAPA 3123 was close, but the threads were different. Took them back and the guy said it needed a 1-14 thread ??? Old School, give me a number and I'll check that out. Thanks all.
It's pouring down rain right now here. I'll walk down to my boat when it stops and get the numbers for you.
Craig
Dan,
Sorry about taking so long to respond, but I have bad news. The WIX filter # that I switched to is WIX 33418. The problem is that it's about 7.5 inches long + the petcock on the bottom of it. Too long for sure for your application. Sorry about the mis-info.
Craig
The housing was purchased @ Eddie Marine about 3 years ago. I'll ck. out that Fram #. Thanks and thanks for checking anyway Old School.
Hey Dan,
Have you tried the WIX 33405? It is a 1x14 thread and including the petcock is just over 7" long. I use it on some equipment and thought it may work. Here is a list of a other 1x14 filters that cross with it but are different lengths etc.
Caterpillar Primary Filter/Water Separator 175-2949 (threads 1-14 UNS-2B )
Fleetguard FS19683
Donaldson P551743
Baldwin BF1268
Wix 33005
Luber-Finer LFF8030
ACDelco TP1002
Caterpillar Secondary Filter 1R-0749 (2 Microns) (threads 1-14 UNS-2B )
Fleetguard FF5319
Donaldson P551311
Baldwin BF7587 (BF614, Standard Version, BF7633, Short Version)
Wix 33674
Luber-Finer LFF2749 (High efficiency version of LFF5823B)
ACDelco TP1322
Fram P8335
Purolator F75185
Hastings FF1056 (FF1007, Standard Version FF1079, Short Version))
Caterpillar Filter 1R-0750 (2 micron) (threads 1-14 UNS-2B )
Fleetguard FF5320
Donaldson P551313
Baldwin BF7633 (BF7587, Long Version)
Wix 33528
Luber-Finer LFF3347
ACDelco TP1326
Fram P8334
Purolator F65213
Hastings FF1079 (FF1056, Long Version)
