Trailering Question
Perlmudder
So we are taking out boat in for some warranty work next weekend. The trip will be about a 175 miles there and a 175 miles back. I dropped the trailer off at a local shop and had them check out the bearings and make sure the brake calipers are tight (we have broken 2 due to the bolts coming loose). It has surge breaks so I will check the break fluid before we head off. Not a very long trip compared to some of you guys, but I really don't feel like breaking down on the highway.
Anything else I should check before leaving?
Thanks!
-Josh
Here is a map of the route we will take. Will probably leave the cottage Sunday night and head back to Toronto, then on Monday head to Cobourg.
Thanks!
-Josh
Make sure you have a spare and the proper tools to change it...sounds stupid but you would be surprised. I always check the tire pressure as well (check the spare PSI too!). The trailer place probably already made sure the bearings were greased, but might be worth another look.
Yeah- straps on the back. Gravity is rarely your friend.
Check your hitch. I've seen them loose, rusted, cracked, etc. Also check the hitch ball for tightness. Take a close look at the tow vehicle too. This is it's biggest, most strenuous job of the year.
Pick up a Laser Pyrometer to keep an eye on bearings, tires, and brake temps.
Also, once you have a jack that works on your trailer: I suggest a 12"x12" piece of plate steel (from Home Depot or Lowes) to carry with you to place the jack on when needed especially on soft/loose ground.
Thanx guys! Ive got the straps that came with the boat for the back, and a rachet one I always use on the bow eye. I just bought a new trailer ball for for 6k and the bar is good for the same. Since its a new ball, I have heard of putting grease on it? I have a tube of regular grease I bought for bearings so that should be fine, right? The trailer hitch is only a month or so old, we just bought the truck. But I will put a wrench to it just in case. I checked the lights last weekend and they seem to be in perfect working condition. We however do not have a spare or a jack... maybe I will see if I can borrow one during the week from someone.
As for the jack, wood works better. But only on multi axle trailers. Just put in front of the good tire like steps (usually 2 or 3 2x6x6 stacked) and pull forward to raise the bad tire off the ground. Don't forget to loosen the lugs on the bad tire first.
I have a small floor jack, wood chocks and a good socket set I always bring with me. If you don't have a lazer pyrometer, I always stop after the first 100 miles, and put my hand on the tires and bearings. You will know right away if one is heating up. Also, just as a precaution I welded the nut of the ball to the hitch after I had tightened it up. I had two come loose on me (no problems thankfully) but had I not checked them enroute, it could have been! If you give everything a once over every time you stop you can usually catch a problem before it becomes a major issue. I always start at the hitch, check the bow tie downs, driver side wheels/bearings, rear straps and then up the passenger side.
Don't forget a small chain. You might get in a situation where you just can't put a wheel back on. Jack the axle up & secure it with the chain & limp her on it.
I have a big Dewalt bag that I carry my **** in.
2 bottle jacks, a 4 way lug wrench, spare bearings & seals, grease & grease gun, multimeter, seal drivers, electrical tape, Oklahoma socket set (cresent wrench), a pipe wrench, a rubber mallet, bearing buddies, lug nuts, chain, screw together chain links, flash light & batteries, both rubber & leather gloves, needle nose & regular pliers, flat blade screwdriver & I think that is it.
