If you have a new one welded on, just make sure they tig weld. Mig welding the skeg on is not good enough. It doesn't make enough heat and the weld will usually fail. You really should disassemble the lower to properly weld the skeg on. If you don't, be careful to keep the seal area cool so as not to damage the seal.
Eddie
