shower drain issue.
Nevr2nd
My fellow Black Thunder owners,
My shower will not drain, even with the pump running. I checked to se if it was clogged, couldn't really tell.
Has anyone experienced this situation???
Thank you,
Eric
97, 43 SC.
Thank you,
Eric
97, 43 SC.
Could have a small crack in the line, sucking air
The pump is under/behind the stairs. Pull the back stair panel and check the box for a bad hose, plugged, etc. That's the easiest place to run a wire up into the shower through the hose also.
