Removal of trim pump hoses
Donskihp
Got a new drive trim pump tank, want to relocate pump to a different location. To do that will require longer hydrolic lines. On the Brovo 1 drive the lines appear to run through the gimble and to the bottom on the outside to a distribution block. If I pull the block and disconnect the lines will they easily pull out and will new longer lines easily push through, without pulling the motor? I took off the 2 nuts from the block, but it dosen't seem to pull down very easy, any suggestions?
Don the hoses will pull out of the transom plate easily. The problem will be they are usually clamped down against the transom to keep them from touching the down tubes of the exhaust. Mercury offers extension hose kits. That will be the easiest way to go.
I found the hoses clamped on one stringer,which wouldn't be to hard to get to. Did't know mercury made extensions,good to know, I think I'll go with the extensions and replace latter down the road when I do an engine refresh. Appreciate the info. Donzi mounted the tank right infront of the best spot to access the bilge, moving the pump just makes oil changes and cleaning easier.
You know, I found that shaving a line wrench down on my grinder made the wrench narrower and easier to get between the fitting and the shoulder of the jacket on the line to get the line wrench on the fitting. I have two line wrenches for some reason, so one became a skinny size and one stayed wide. Very handy.
excellent idea
I removed old lines and got some longer ones from league. the lines from league they said were for drive trim.receiving them they are mercury # 32-845977. they appear to be smaller ain diameter.looking them up on mercury web some they are for trim tabs. If i take them out of the plastic wrapping i can'T RETURN THEM. DOES ANYone know if from tab lines are the same as the drive line
They are them same size and fittings on pre Alpha drives and TRS. Alpha and Bravo drives have larger lines and fittings.
Talked to Tom Gongola,at Latham Marine, early last month and he fixed me up with some custom made stainless Steel lines.They worked like a charm! and exactly the lenght I wanted.
