I'm gonna give you my best guess, based on what some others have run. But, what prop, drive, etc are you running now? If we can get that, then we can get in contact with Brett and see what he's done with similar setups.
My best guess, you're looking at spinning a 24 or 25 pitch 4 blade with a little lab work.
You will also need to check your x dimension. Believe it or not, they actually came setup differently as they learned what performed the best. If yours is low, you will not want to have sternlift, and some 4 blades definitely have more than 3 blades. If yours is higher, sternlift from a prop will be somewhat okay, as long as it is not excessive.
So;
Current Prop brand, pitch, diameter, model
X Dimension
Drive model
Speed @ RPM
