Plug wires.
The big blue Moroso's with the insulating sleeve. They make a set precut to go under marine exhausts.
The MSD 8.5 mm is the absolute best wire on the market. We have done multiple tests from dyno to ohm testing. I am a Dealer for them if you need wires. Thanks.
Dean Gellner
Dean Gellner
They might be a good wire, but I switched to them last year on my boat and I can't stand the fact that you really have to work at it to get them to "click" on.
Taylor the only wire to use imop i like the 10mm you don't need them that big they they look good , also it is the only wire we have found that does not burn on dyno dry headers,MSD did not last 3 pulls
