PLATINUM SERIES (Arched, Standard and Billet)
Introducing the all NEW completely redesigned PLATINUM SERIES from Livorsi Marine. The PLATINUM SERIES is designed to be more ergonomically comfortable to the operator while being lighter and more compact for fitting into tight spaces. The Platinum series is finished with a two coat process which prevents corrosion and can be configured for single or multiple engine's for Drives, Transmissions, Jet Drives or Buckets. Available in three throttle/shift configurations: Fully Mechanical, Fully Electric or Mechanical/Electric (Hybrid).
The Platinum Series has 3 different styles that can be customized in any configuration imaginable. The styles include; The Standard series for the classic look, The Billet series for racing performance look, and the Arched series for the modern "edgy" performance look.
All three new styles allow you to choose your throttle base in flat or our NEW Contoured Base; available in an array of Colors, Chrome or Carbon Fiber. Further finish your throttles with your choice of 1, 2 or 3 switches in the knob to actuate your drive, tabs, jackplate, etc. As always, the knobs are available in 12 different color options to match most any style or color of your dash helm.
These controls are compatible with throttle, shift, jet drives or buckets (1 function per handle), 33C or 43C cables
There are three different styles to choose from- Standard, Billet or Arched
Billet aluminum construction makes these controls tough yet lightweight
Corrosion Resistant, two layers of protection-
anodized base coat
powder coat finish
Shorter base depth: mechanical units measure 8.125" deep, while the electric units measure 6.5"
Ergonomic knobs for long hours of comfortable operation
Controls feature friction and detent that may be adjusted while installed on your helm
Flat base and the optional contour base color options include chrome, simulated carbon fiber or a powder coat finish
Configurations include one or any combination of the below:
The use of mechanical 33C or 43C cables for mechanical levers
Electric configurations use compact direct driven angular sensors - 0-5 Volt electronic sensors or a PWM signal
The use of a micro switch - for electronic transmission shifting
Single, twin and triple in-handle trim switch available as shown on the chrome control above
Check with the engine manufacturer or Livorsi Marine for electric control compatibility
For more information please call 847.752.2700 or if you are going to be attending the IBEX Show in Tampa Florida, Sept 29th - Oct. 2nd stop by booth 1516.
If you would like to make an appointment to visit with Mike Livorsi at the booth, please email Mike at mikel@livorsi.com
