formulator
Hi there
Im installing oil coolers on my 2008 Formula 292 Fastech twin mercury marine mx 6.2 377 sb they been great little stout engines but 4.5 quarts after running hard on a hot summer day, makes me a little nervous., oil psi is fine 40psi when cold and warm. but merc could have given this little beast one more quart , so im instaling oil coolers and oil temp sensors , hardin marine temp gauge which will be connected to a on off on toggle switch for reading port and starboard engines temps, talked to Rick at cpperformance which he was the best help and fast delivery not to mention knowledgeable, My Question is such ... is the oil cooler a good place to install a adapter for the sensor on the out line of the cooler . or does it need to be closer to the engine oil pan return , any advice or experience would be much appreciated thanks aka FORMULATOR
