offshore24
Ran the boat easy all day, maybe 3500 RPM's all day. When coming in I noticed maybe 5 lbs oil pressure. If I revved it maybe 8 lbs. No knocking, banging, clunking, just valves tapping. Pull the pan hoping to find the oil pump pickup off, rebuilt the motor 2 seasons ago and put a new pump in and welded the pick up on. It's still on. Pull #2 main bearing looks OK. Pull #1 rod cap, bearing looks OK. Any ideas as to where to go from here. Engine has maybe 40 - 50 hours.
