US1Fountain
I need to fill in the area on my transom where the gimble assemblies mount. At the top and bottom of the cutout, the gel has been worn down enough to not have a flat surface to mount the gimble assemblies to. I replaced the transom wood do to rot and it looks like the assemblies sucked into the gel. Still shiney gel, not dull from moving around. Just as if the wood was soft and the gimble units where pulled in. Not a huge amount, approx 1/16" or so at top and bottom. The middle is fine and flush when checked across wises, but is high when checked up/down within the gimble housing surface area, which is giving me a rocking on that point. I tried sanding the center down some and have a ways to go to get it flat, but I think the right way is to level the top and bottom back out. I'm right at 2" thick, so no room to get carried away sanding the center down.
What is the process for doing this?
I believe need to sand the gel off around the cutout down to bare glass, and add filler and sand flat, but not sure on what type of filler to use. I have some Cabisol from US Composites and some West System high density left over. Going to use Vinlyester resin as that's what I have used and am comfortable with it.
I see fillers that are easier to sand, but not sure about the compression charactristics of them for this application, plus if I can use the Cabisol, rather use it up vs buy more filler and just work harder at sanding. The area needing leveled out is just within the mounting area. Outside that it is flat.
Thanks
Thanks
