Need Batter Box Top and Hatch Actuator
.38Special
Need one GIL replacement top for battery (will consider plastic or metal, prefer metal) and does not have to be GIL.
And a hatch acutator. It measures 41.5" open and 24" closed. All of the aftermarket acutators seem to be different lengths and I would prefer not to install new mounts. It is an 18" lift. Thanks.
I have the plastic top for your batt box or new SS batt boxes, the new ones i sell for 65 bucks and the plastic top one u can have for 20 shipped !!!!
Actuator.....just replace the motor !!!!!!! or if it leaks , the seals !!!!!!!
i have that battery box and i do not use it anymore. it is complete. if you need more than what daredevil has lemme know.
I have searched high and low and cannot find the motor anywhere. I've been to electric shops, marinas, etc... Any ideas. It has the worm gear attached to it.
Daredevil, I'll take the battery top.
I bet u bring it to a altenator shop they can fix it !! :confused:
Or i would go and stick a new one in,, electric/hydraulic.
the mount should be fine, it may open a little higher and on the closing part,,,just stop pushing the button when its all the way down.
I'm afraid the ram will bottom out before it is closed, that's the problem. Tried a starter/altenator rebuild shop, they said no. I'll probably just have to try a new one. Thanks.
