Methane / ICE injection systems?
NJgr8ful
Methanol/Meth/ICE Injection
Anyone or any of our SO Tech Expert guys have experience with this set-up?? ((Posted down in TECH too just wanted to get views))
TIA Chris :bigear:
check with runnin hot racing, there is a thread on oso on it. the only problem Isee is if you run out of fuel you burn up your motor.
Brad Zastrow installed this set up on his MTI and loves it.
I think its a well designed and built system. I said it before and got reamed, but its a little pricey.
I guess if you can safely run 93 and still put 9+ Lbs of boost to the engines there is a trade off and probably a big savings.
Why did you get 'reamed'??? :confused:
:) gotcha, in 2 seconds, you would have 8 really expensive ash trays. :ack2:
LOL :D ... not so funny :eek: I knew what Wiggler was referring to Meth v. Gas emptying out. That's why I wanna go with like 10 gal Meth tank, or even dual ICE tanks.
if you run out of fuel ????????? Dont run out of fuel :sifone:
We run 1 -20 gallon tank to feed each motor and on the average poker run we've burn thru 3 to 5 gallons ... Call Diamond RUDY :seeya:
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I said it before and got reamed, but its a little pricey.????
Have you priced a new motor lately :rofl::leaving:
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:26:
No I just told Jim about the BAD side of this system a week ago.
Did'nt know there was a Badd side , If you can build a motor for 118 octane and run 93 octane & spray Meth not seeing the Badd side :sifone: help me out here ... when you can put on the kit and cool the charge with meth and take 8 -10 jet sizes out mmmmmmmmmmmmm .
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
how did your injection turn out bill?
Wait till a pump,wire,no alk,or many other small things that might and will go wrong.
Good by motor ...or $20,000 in repairs.:03:
