smittyseng
I'm going to climb on my soapbox (as I have done in the past)-A good suggestion for everyone BEFORE they put there boat away for the winter-Do a compression test on your motor/motors in your boat before you finalize your storage prep for the winter. Find your weakest cylinder, screw the leakdown tester gauge that EVERYONE should own (they are only 40-75 $ at local autoparts store) in that particular cylinder and see what you got. If its unsatisfactory (20% is somewhat low-30% is real low) you will have all winter to address it INSTEAD of having problems at the beginning of next season that ruin your boating season!!!!! Another thing EVERYONE should think of doing in a ideal world (I have always done this) is after dynoing your motor or breaking in a new motor do both test on every cylinder,write down the numbers in your detailed notes you should be keeping for FUTURE comparison then later if you suspect your motor isn't running a 100% you will have a basepoint later on or something to compare your numbers to when doing your ANNUAL test! If your numbers are bad after breaking in or dynoing you know what you need to do too,Smitty
