I need to find AN hose fittings, Tee's and AN to NPT adaptors in stainless steel. Where can I find them?
Running into a brick wall!
Thanks in advance for the help!
Aeroquip and Parker both catalog a significant range of them. But unless you're in a big city, they're probably special order. Try McMaster-Carr. www.mcmaster.com
The question is, why do you need S/S? Unless it's steering, aluminum works perfectly fine. You need steel for the steering's PSI. And the steering guys all stock the fittings.
