Computer Experts ?
GregP
Does anyone know how to check a Hijackthis log? I tried several of the on-line log analysers but don't have much faith in them since the 3 I tried all gave different analyses of the same logfile. The problem I'm trying to crack is that the "system" process has started using 50% of the CPU when nothing is active (not the "System Idle process"). It started after my daughter used my system for Facebook. I went back to a prior checkpoint and it went away, but now it is back and nothing I've tried seems to find/fix/change it.
I've run full scans using MacAfeee, Symantic and Adaware. Adaware found one file I removed and for a while the "system" process when back to using no cpu after I rebooted, but now it is back to 50% and re-running both scans doesn't pull up anything.
The other symptom is that when I tell the system to shutdown it eventually stops doing stuff but never shuts down or gives the "safe to shutdown" message. Sometimes it will go to a blank screen, sometimes it just stops still on the Windows is shutting down screen. It has all the updates except XP SP3 which I was told by the IT people at work not to install as they were having problems that after installing SP3 none of the systems could access any printers.
Thanks - Greg
Like HiPerf said post the results and let us have a look. Download Malware Bytes and run it and post that log also. it is a free program
I'll post it when I get home tonight. I used to run SpyBot but stopped when it locked out the travel sites a couple years ago. I'll also look for the Malware Bytes program.
Thanks - Greg
Here is the HijackTHis Log, will try the malwarebytes shortly - Greg
Logfile of HijackThis v1.99.1
Scan saved at 7:36:37 PM, on 11/3/2009
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
c:\Program Files\Hewlett-Packard\Drive Encryption\HpFkCrypt.exe
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\LSI SoftModem\agrsmsvc.exe
C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
C:\WINDOWS\system32\mqsvc.exe
C:\Program Files\Hewlett-Packard\Shared\hpqWmiEx.exe
C:\WINDOWS\system32\mqtgsvc.exe
C:\WINDOWS\System32\Drivers\Kanguru_SAP\FD_Hide.EXE
C:\Program Files\Hewlett-Packard\IAM\bin\asghost.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\PTHOSTTR.EXE
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\WINDOWS\SMINST\Scheduler.exe
C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
C:\WINDOWS\system32\AccelerometerSt.exe
C:\Program Files\eFax Messenger 4.3\J2GDllCmd.exe
C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe
C:\Program Files\Hewlett-Packard\Shared\HpqToaster.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
C:\Program Files\eFax Messenger 4.3\J2GTray.exe
C:\Program Files\palmOne\Hotsync.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\WinZip\WZQKPICK.EXE
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqimzone.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqSTE08.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\Program Files\Hijackthis\HijackThis.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=74&bd=smb&pf=laptop
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=74&bd=smb&pf=laptop
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=74&bd=smb&pf=laptop
N3 - Netscape 7: user_pref("browser.startup.homepage", "http://home.netscape.com/bookmark/7_1/home.html"); (C:\Documents and Settings\Greg\Application Data\Mozilla\Profiles\default\kl5bno21.slt\prefs.js)
N3 - Netscape 7: user_pref("browser.search.defaultengine", ""); (C:\Documents and Settings\Greg\Application Data\Mozilla\Profiles\default\kl5bno21.slt\prefs.js)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: AOL Toolbar Launcher - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - C:\Program Files\AOL\AOL Toolbar 5.0\aoltb.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: Credential Manager for HP ProtectTools - {DF21F1DB-80C6-11D3-9483-B03D0EC10000} - C:\Program Files\Hewlett-Packard\IAM\Bin\ItIEAddIn.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: AOL Toolbar - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AOL Toolbar 5.0\aoltb.dll
O4 - HKLM\..\Run: [MsmqIntCert] regsvr32 /s mqrt.dll
O4 - HKLM\..\Run: [SoundMAX] C:\Program Files\Analog Devices\SoundMAX\Smax4.exe /tray
O4 - HKLM\..\Run: [PTHOSTTR] C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\PTHOSTTR.EXE /Start
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [hpWirelessAssistant] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [CognizanceTS] rundll32.exe C:\PROGRA~1\HEWLET~1\IAM\Bin\ASTSVCC.dll,RegisterModule
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\Sminst\Recguard.exe
O4 - HKLM\..\Run: [Reminder] C:\WINDOWS\Creator\Remind_XP.exe
O4 - HKLM\..\Run: [Scheduler] C:\WINDOWS\SMINST\Scheduler.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [Cpqset] C:\Program Files\Hewlett-Packard\Default Settings\cpqset.exe
O4 - HKLM\..\Run: [WatchDog] C:\Program Files\InterVideo\DVD Check\DVDCheck.exe
O4 - HKLM\..\Run: [AccelerometerSysTrayApplet] C:\WINDOWS\system32\AccelerometerSt.exe
O4 - HKLM\..\Run: [eFax 4.3] "C:\Program Files\eFax Messenger 4.3\J2GDllCmd.exe" /R
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [BlackBerryAutoUpdate] C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe /background
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
O4 - Startup: CCC.lnk = ?
O4 - Startup: palmOne Registration.lnk = C:\Program Files\palmOne\register.exe
O4 - Global Startup: Bluetooth.lnk = ?
O4 - Global Startup: DVD Check.lnk = C:\Program Files\InterVideo\DVD Check\DVDCheck.exe
O4 - Global Startup: eFax 4.3.lnk = C:\Program Files\eFax Messenger 4.3\J2GTray.exe
O4 - Global Startup: HOTSYNCSHORTCUTNAME.lnk = C:\Program Files\palmOne\Hotsync.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
O8 - Extra context menu item: &AOL Toolbar Search - c:\program files\aol\aol toolbar 5.0\resources\en-US\local\search.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: AOL Toolbar - {3369AF0D-62E9-4bda-8103-B4C75499B578} - C:\Program Files\AOL\AOL Toolbar 5.0\aoltb.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\Office12\REFIEBAR.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=74&bd=smb&pf=laptop
O16 - DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} (Office Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=58813
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - http://photo.walgreens.com/WalgreensActivia.cab
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} (GMNRev Class) - http://h20270.www2.hp.com/ediags/gmn2/install/HPProductDetection2.cab
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL
O20 - AppInit_DLLs: APSHook.dll
O20 - Winlogon Notify: FaSrv - C:\WINDOWS\SYSTEM32\FaSrv.DLL
O20 - Winlogon Notify: OneCard - C:\Program Files\Hewlett-Packard\IAM\Bin\ASWLNPkg.dll
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\Program Files\LSI SoftModem\agrsmsvc.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (file missing)
O23 - Service: Symantec Settings Manager (ccSetMgr) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (file missing)
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Drive Encryption Service (HpFkCryptService) - SafeBoot International - c:\Program Files\Hewlett-Packard\Drive Encryption\HpFkCrypt.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqWmiEx.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: Intuit Update Service (IntuitUpdateService) - Intuit Inc. - C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
O23 - Service: IviRegMgr - InterVideo - C:\Program Files\Common Files\InterVideo\RegMgr\iviRegMgr.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Unknown owner - C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf (file missing)
O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: PC Angel (PCA) - SoftThinks - C:\WINDOWS\SMINST\PCAngel.exe
O23 - Service: Symantec Management Client (SmcService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
O23 - Service: Symantec Network Access Control (SNAC) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\SNAC.EXE
O23 - Service: stllssvr - MicroVision Development, Inc. - c:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: Symantec Endpoint Protection (Symantec AntiVirus) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
Run Task Manager and see what process is hogging the cpu all the time. If you find a cpu hog, Google what the process is and see if it's safe to disable. Then see if the problem goes away.
BTW, Symantic AntiVirus is a hog all by itself. Try Avast. It's free and isn't a resource hog.
I know which process it is, the "system" process (not "system idle"). I just can't find what it thinks it is doing when no user processes are running.
I see the refs to AOL and google toolbars, but none of them are active in Explorer so I don't know where they think they are running either.
The Malwarebyte program didn't find anything in it's report.
-Greg
Try booting into safe mode and see if things are normal. You might need to go into RUN>MSCONFIG and shut down one process at a time to locate the bugger.
you have alot going on there, but it all looks valid.
this one looks strange though...................
Do Like MacGyver said and do the mscongfig and click on the startup tab. do a screen print of it and post it here. We can tell you what you can turn off at startup. You may have alot running in the backround you don't need
Just for chits and grins, run task manager and shut down ALL Symantec stuff and see if things go back to normal. Symantec likes to run a ton of crap in the background.
If you have a memory hog process, your computer has been "powned" or you are now part of a BotNet more than likely. Try physically killing/disconnecting your Internet connection and see if the CPU and Memory utilization goes down.
I work for Symantec, and I'll admit that the old AV stuff was a bit slow. But imagine this: We put out up 10,000 to 25,000 malware/threat/vulnerability signatures EVERY DAY. That's a lot of work for an AV product to to do round hole/square peg type of checking on each and every bit of code to see if its good or not. Hence, "bloated AV product" sentiments.
Do yourself a favor and upgrade to Symantec Norton Internet Security 2010. It's got the goods aka, it's got a ton of other technology that augments and takes the load off of the "AV" portion of security and makes things more secure and does it faster.
